Cultivator/Spring tooth build
9,980
Spent most of yesterday making a Cultivator/Spring tooth for the B7100.
The square tube is 3" 3/8 thick so it's got enough weight.
The last one I made was 3 tooth and it just didn't have enough weight to work efficiently!
9,980
Thanks!:D
I have found that with a little steel and a few tools I can build most of what I need or want for cheaper than I can buy it pre built.;)
Besides It keeps me busy and out of trouble.:rolleyes:
gpreuss
Oct 9, 2011
1,166
Spokane, WA
Great job! How did you mount the springs?
9,980
The springs are bolted to the 3" tube with 1/2" grade 8 bolts.
I drilled the holes for the bolts the drilled two small holes next to the original 1/2" hole, I then fed the bolts inside the tube and into the holes then welded them in place with the 2 smaller holes.
It made for a cleaner look over having long bolts sticking out the top of the tubes.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
Thanks! I'm looking for a field harrow to knock down the clumps at my place. That could do the job!
9,980
If your not up to building one yourself let me know and I could build one for you, you could even go a little wider with your L pulling it.;)
