B BillFL New member Equipment L3901, Flail mower, Bush hog, Disc harrow, spreader, forks, Dec 2, 2023 1 0 1 32168 Dec 2, 2023 #1 Countyline Tiller gearbox will not accept slip clutch or regular pto. Looking for possible solutions.
mcfarmall Well-known member Equipment Kubota M5660SUHD, Farmall C Sep 11, 2013 1,431 1,717 113 Kalamazoo, MI Dec 2, 2023 #2 How about some pictures of the gearbox input shaft and the desired mating end of the shaft?
G GreensvilleJay Well-known member Equipment BX23-S,57 A-C D-14,58 A-C D-14, 57 A-C D-14,tiller,cults,Millcreek 25G spreader, Apr 2, 2019 12,969 5,693 113 Greensville,Ontario,Canada Dec 2, 2023 #3 and /or the model number ?
O Outnumbered Well-known member Equipment Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Forks, 55" Grapple, 5' Tiller ..... Oct 26, 2019 249 444 63 Moseley, VA Dec 2, 2023 #4 I have one with the slip clutch I picked up about 4 years ago, no issues to date.
Fordtech86 Well-known member Lifetime Member Equipment L3200 Aug 7, 2018 4,966 5,916 113 Pineville,LA Dec 2, 2023 #5 Outnumbered said: I have one with the slip clutch I picked up about 4 years ago, no issues to date. Click to expand... same here, mine came with slip clutch installed
Lencho Active member Lifetime Member Equipment B7100hst Jan 21, 2017 428 101 43 NM Dec 7, 2023 #6 Photos would help. Mine also came with a slip clutch from TSC. The PTO shaft is pretty short. You may need to cut yours to make room. Attachments IMG_0614.jpeg 176 KB Views: 129
