Bought the tractor had a wiring fire replaced harness everything works on first road test went into gear drove around 5 mins when through all gears fine in all ranges as I was pulling back in lost steering and trans coded out with er38 and er 42 replaced suction filter and new fluid started it back up went into gear drove around did the same thing 1900 hrs had Kubota in to look at it said I need a new pump when it screws up you can punt your hand on the main line to the 3pt hitch and it’s cavitating. is there a suction screen on this model or other relief valves that could cause this any help would be appreciated
