Clutch or hydraulic pump ?
Grace haven
L355SS
Nov 8, 2020
17
Maryland
Just bought a l355SS starts and runs fine but will only move on 1st and second gear. Front end loader operates as it should although slow at low rpm. Do I have a bad clutch or low hydraulic pressure?
Thanks
Roadworthy
L2501 HST
Aug 17, 2019
1,647
526
Benton City, WA
Hydraulics are normally slow at low engine speeds. You don't mention what transmission you have. If you have released your brake and and have a standard transmission (rather than HST) you could have clutch issues, though it may be a simple adjustment.
8,251
And L355SS uses a hydraulic clutch and a mechanical clutch but it sounds like you have a mechanical clutch issue.
Go to Kubotabooks.com and it will tell you how to test the feed pressure for the hydraulic clutch.
wgator
L4701HST, FEL and other stuff.
Jul 28, 2018
482
147
NC
Another suggestion is check out this OTT thread that sounds similar:
Grace haven
L355SS
Nov 8, 2020
17
Maryland
I disassembled the priority valve and found that it was operating correctly. anyone know where I could find a clutch kit ? or the individual parts. also can I get away with just replacing the clutch discount and not the pressure plate ?
thanks
