Clogged Zerks
jmusits
B2301, L434 Loader, B2673 w/ Hyd. Angle, EA 54" XTreme Duty Compact Box Blade
Mar 26, 2017
15
Greenfield Center, NY
Hi all,
I have a B2301 with just under 100 hours on it. My old reliable grease gun finally gave up the ghost, so I just got a new one. First time greasing up the loader two of the zerks would not accept grease. I tried adjusting the fitting on the grease gun to no avail.
Can the zerks be pulled out and flushed or cleaned with oil, or is my best bet to go ahead and replace the fittings. Kind of a strange coincidence as I have never had any issues greasing things before and this just started the first time I used the new gun.
Thanks!
Jason
Captain13
Feb 27, 2019
523
171
Kathleen, GA
I had the same problem yesterday greasing my ZTR and Grooming Mower. What I usually do is take a small flat tip screwdriver and just press on the ball to break it free. Sometimes my thumbnail works, too. If it still doesn't want to take grease, I remove it and make sure it's not hardened grease inside the zerk by just pumping a squirt through it.
5,553
I just went to TS and picked up a pack of I think 10,,,they are metric for a couple bucks replaces the offenders and that was it done is done
jmusits
Mar 26, 2017
15
Thanks for the responses everyone! Once I have a chance to dig into it I'll post back with results.
SDT
Apr 15, 2018
3,681
1,406
Hi all,
Thanks!
Jason
Impact type zerk "cleaners" are available but it's probably easiest to just replace some or all.
SDT
mikester
M59 TLB
Oct 21, 2017
4,122
2,815
www.divergentstuff.ca
SDT
Agreed. Buy a zerk fitting assortment kit and just toss out the ones that dont work. Why would you want to force the dirt/crud blocking the zerk directly into your pins and bushings? Penny wise...
Captain13
Feb 27, 2019
523
171
Kathleen, GA
I will usually replace mine. However, if I don't have any replacements available, I will "unstick" the ball after I've cleaned it.
