I tried a Chaping mixes on exit sprayer today and was not impressed. It is suppose to mix the chemical and water as you spray and leave you with a tank of clean water when done so there is no waste. Also you can switch the chem tanks if you need to spray a different chem mid application. Well the chem tank is bleeding back in to the main water tank and defeats the whole purpose. I added tracker dye to my chem tank and noticed later my water tank turning blue.
