Have an old L225, and I don't like the look of the tranny fluid (who knows, might be the original.....) I have drained it but am thinking about how to push all the hydraulic fluid out of a backhoe on the tractor. I'm probably going to disconnect the return line and see if I can catch everything so it does not contaminate the new oil in the tranny.
My question is, if all the backhoe controls are neutral, does the oil recirculate back into the tractor tranny, or does the valves shut off the flow and the pump just work against a regulator valve to maintain a constant pressure?
I plan on disconnecting hoses to excercise each cylinder and push out as much old oil as possible.
Thanks for any suggestions
Frank
Frank
