Change B6200 Glow Plugs
the engineers
B6200HSTD, Westendorf TA-55 FEL
Jul 15, 2014
14
Lincoln, NE
I did some searching, but came up blank.
Do I need to take the intake manifold off to change glow plugs? I unthreaded the front plug until it hit the injector lines...easy enough to undo that. The other two don't look like they'll clear the intake. I couldn't even get the terminal nut off the middle plug...
Please help.
the engineers
Jul 15, 2014
14
Lincoln, NE
I messed around with this some more to make sure that I'm not crazy. Also, I downloaded the manual for the D750...not helpful.
Has anyone else changed the glow plugs on their D750?
Here's a pic...
8,745
First go to Kubotabooks.com and download the WSM for your B6200 if you don't already have it.
Second yes you need to remove the injector lines and the intake manifold to get the glow plugs out easily.
the engineers
Jul 15, 2014
14
Lincoln, NE
I have the manual. It doesn't cover much for the motor...basically just maintenance items. I downloaded the D750 motor manual, but it only addressing testing glow plugs, not removal.
Thanks for the reply, though.
