Have not been able to start the G6200 tractor. So, I figured I'd take off the solenoid wire which connected to the starter switch and jump directly from battery to solenoid terminal. I got a simple 2 pole switch and connected the switch between the battery and the solenoid terminal. No luck, even jumping with my truck produced a weak turning of the engine and with no starting.
I'm guessing this switch is not polarized and you can use it either way and have no problem.
Does this make any sense or have I broken some law of electricity? I was not able to find out what was wrong when trying to start the engine with the standard set up. So, figured I'd go to the battery hot terminal and put the switch between battery and solenoid. Can't believe I can start this thing, makes me crazy.
