Can't grease loader bucket pins
Bad Bob
L3901 tractor
Oct 6, 2019
Huntingdon,TN
Replaced zurks fittings and still can't grease in. The left side two pins at the end of the loader arm. Any ideas?
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
Sometimes I've seen pins that you had to work the bucket as you tried to grease them. If that doesn't work remove the pins and clean the grease vein then put them back in.
After that use quality grease so they don't get plugged up again.
tthorkil
M9540HDC12 / LX2610HSDC / ZD1011-48 / Bobcat S250
Jan 1, 2011
323
87
Bagley, MN, United States
I borrowed my nephews backhoe attachment for the Bobcat and evidently he had not greased it in quite some time. I tried to get grease to go in - removed and replaced the zerk - no luck - I ended up taking a small pick and slowly worked at chipping away the petrified grease until I got through to the pin and then put the original zerk back in..
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
528
494
Lake Almanor, Ca
This...or push the pins out and clean or replace. My backhoe get crap jammed in the zerks...occasional plugging them. I have a couple extra pins to swap in and clean out the old ones to use later...
wgator
L4701HST, FEL and other stuff.
Jul 28, 2018
482
147
NC
On my L4701 I have to raise the bucket to chest level with a slight dump to get grease into the pins at bucket end of loader arms.
SidecarFlip
Banned
557
The easiest and best fix is...DON'T USE CHEAP CLAY BASED GREASE that hardens and clogs the passages. I have zero issues greasing any of my dozens of fittings on my tractors or implements because I don't ever use cheap clay based grease.
Clay is best used for pottery, not grease.
IOW, don't buy the cheap TSC Traveller grease in tubes. it's crap.
2,961
I generally replace plugged zerks, it's the quickest and least painful solution. But I sometimes find that the old dried grease & crud that blocked the zerk has also blocked the grease passages. In that case, I use the tool GeoHorn posted. Works every time.
