Can someone help with what to fix
Whiskey Tango Farms
L3301, zd1511, RTV-X
Jun 6, 2023
Minnesota
I have a warning light on, on the control panel. I have now changed all the fluids and filters. I just changed the oil pressure sensor.
What should I do next.
sagor
Jan 9, 2017
288
65
Sudbury, ON, Canada
Not sure, but it might suggest that some regeneration is due or previous regeneration has failed (or got interrupted)?
Don't ignore it!
5,709
I'd hope the owner's manual has a chart of list of why the orange ! came on. if not ask the dealer you bought it from ?
RBsingl
Jul 1, 2022
485
562
Central IL
If it is flashing, it is telling you to stop operations and immediately begin a parked regen to allow the DPF to clean itself. If it is on steady, it is too late for a parked regen and you should contact your dealer. Do NOT continue operating or it will get more expensive.
If it is steady, you should have gotten a flashing alarm prior to this process. In any case, it needs help from a dealer tech because it is unable to regen.
Rodger
