Can I "float" the front mount snowblower?
oldryder
b2410
Apr 23, 2017
31
Avon
B2410 with loader (LA-352-1) and B2650 blower.
Got everything working. Wondering if there is a way to allow the blower to "float" once it's lowered?
Thx to anyone offering advice.
mark in MN
Howling
BX2370
Feb 5, 2016
217
10
Ayer, MA
The blower lift is connected to loader valve. So the loader float control will do the same for the blower.
oldryder
b2410
Apr 23, 2017
31
Avon
Howling;
thx for reply. I've never used the loader float function (actually didn't know there was one) . how does it work?
thx
mark in mn
4,612
Push the lever all the way forward untill it clicks,,no you didnt break it,, sometimes if it has not been used for a long time the detente might be very stiff but do it a few times and you will feel where it clicks that is the float it opens both ports so there is no flow up or down through the valve body. Hope that helps
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
Put the snowblower on or close to the ground, and then do as skeets said. If the loader or attached object is up in the air it will drop when you go past the detent.
If your blower is on skids you might have to wait until the ground freezes or you have a snowpack before you can run it in float without gouging the lawn or dirt. After that it is much better than trying to adjust the height all the time with the loader valve, at least if you have all the little hills and valleys that I do.
