Can a JD8 BH fit L3010
DigVT
L3010
Jul 7, 2017
Peacham VT
I am looking at a JD8 BH with sub frame, wondering if it could be fit to a L3010? The 3010 does not have hydraulics at the rear PTO. Thanks
8,495
Several things come into play:
Is the JD BH you are getting equiped with an open center valve or a closed center valve? It must be an open center valve, a closed center valve will not work.
Your going to take some work to alter the BH bracket to fit your Kubota.
And yes you will have to add a PB loop to the tractor to run the BH. ;)
project_x
69
Ottawa
A JD8 is open Center. I was able to mount it on my L235 using the JD subframe.
I got a B3300 and instead of modifying it, I purchase a kubota subframe and modified the back how to have a 4pt mount like the newer ones. I'm planning a Thread on the entire build, but got stalled with making hardlines for the top n tilt and powerbeyond I am adding for the backhoe.
If you are handy, you should have no issue on your L3010
Sent from my STV100-3 using Tapatalk
DigVT
L3010
Jul 7, 2017
Peacham VT
How difficult, and expensive is it to bring hydraulics to the back PTO area, is that just 2 hose connections? Was the modification of the JD sub frame to the L235 a major project?
Thanks
