cadman
rhammer
M105XDTC
Feb 19, 2014
Summer Shade, KY
Looking to buy a used 500 gallon boom pasture sprayer. I found one but it has a hydraulic pump on it. Will my M105X operate this pump off my remotes as is or will I need to add something to my hydraulic system?
8,682
The remotes on your tractor are for momentary use, use need a remote that will lock on a full flow in order to run a pump from it.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
If your remotes are operated by valves, then you need to connect the pump in the tractor hydraulic line going to or from the valves, not in the valve output ports.
My dealer gave me a line with QDs in series with the FEL valve, so it always has flow. It would be a simple mater of connecting it to the pump or pump control.
