BXpanded bucket hooks
Hedgehog
Bx2370
Apr 5, 2015
25
Fairhaven massachusetts
I'm looking at ordering a pair of the BXpanded bucket hooks and wanted advice on which ones to get. Should I get the 5/16" or 3/8" grab hooks. I will only be using the occasionally, probably with racket straps or maybe chain.
Thank you in advance.
Hedgehog
Bx2370
Apr 5, 2015
25
Nobody?
I was advised by BXpanded that the best seller is the 5/16" because it will handle a 1/4,5/16&3/8" chain. I just don't want to sell myself short and wish that I had bought a different size. These things aren't cheap that's why I'm looking for advice.
Thanks
7,088
I have 2 5/16" grabs and 1 slip hook from Bxpanded. All my chain is 5/16, so good there.
Often use all 3 at once when lifting, with slip hook in the center of the bucket with a strap kind of like a top link, and chain on the grabs to the outside. :cool:
2,897
I too think that 5/16" is the better choice;) - for the reasons mentioned. I have several links of 3/8" - it is heavy and overkill but still fit. I have a few small pieces of 1/4" and they work well for the "little" stuff - the one piece of 5/16 is my go to chain.:)
CDNBX25D
BX25D, Bro-tech wheel spacers/skid plate, Ken's bolt-on hooks, LED light bars
May 24, 2015
12
Saskatchewan
RTGT, you could have saved yourself some welding by just getting the Boltonhooks......I don't have pictures of mine installed but very happy with them and the service from Kenny. I mounted 2 hooks on the top of the bucket and one clevis mount on the inside in the center.
rtgt
B3200
Jul 30, 2015
96
Kentucky
And miss the opportunity to play with the welder....:D
I wanted to re-enforce the mounting position and I wanted the hooks on the top edge of the bucket, hence the angle iron.
I used Kenny's Bolt on Hooks because I wanted to be able to swap to Shackle Mounts if I wanted to.
Agreed, nothing but great service from Kenny.
