bx2680 wheel spacer size
farmer vern
m 6060 / bx 2680 / b7100
Mar 19, 2023
wauconda
i ordered a set of grassmaster turf tires they use the same rims the currennt bar tire does. i have a mmm i decided i would like to use the broteck spacers would like to go to 2 inches can anyone confirm that size would work i believe they also have a 1.5 your help is appreciatted
Bmbbm
Bx2370 land pride box blade 60"mmm kubota fel
May 29, 2016
282
Chillicothe mo
Bmbbm
May 29, 2016
282
Chillicothe mo
Brotek's website should tell you. Part of it depends on your mmm width. I have the 2" spacers on my BX2370 with the 60" inch deck.
1,954
Myself, I would install the new tires and check how much they could be moved out with the MMM installed.
Wheel spacers are not cheap. Certainly would not want to spend the money for something that ended up not working with my MMM.
