BX2680 - replacement for turf tires
TRUCK3
55
Upstate NY
I just picked up a used BX2680. It was used by an older couple with a small amount of acreage and horses. It has turf tires and was primary used for mowing. FEL bucket shows very little use, I was told just for mowing manure which seems accurate.
My use will be FEL work, finish mower and either rotary cutter or flail, and a tiller. I'm not planning on much lawn mowing, but I would like to run across the lawn without tearing it up.
The rear turfs are not filled. If they were I was thinking of running them for a while as is. Since I plan to get the rears filled, I figure I should change out the rears now. I am considering a standard R4 like the Garden Master that Kubota uses, the Carlisle WT300s, and the hybrids - Versa-turfs or R14Ts. Other than the difference in the tread pattern, all but the R14Ts are 4 ply rated, while the R14Ts are 6 ply rated. I'm leaning toward the R14Ts, maybe a little easier on turf than the R4s?, 6 ply rated for field rotary cutting work, and good winter traction if I end up running in the winter at all. Wanted to see what others experience has been on these different tires.
Right now, I'm planning to keep running the front turfs. I don' think there is any mismatch issue on tire diameters for 4wd. All the rear tire options are nominal 26" including the current OTR LiteFoot turfs. All of the tires only seem to vary by 1/10 inch or so in diameter. I see some new Kubota set up with turfs on the front and the "bar turfs" on the rears, local dealer has a B2601 set up that way on their lot.
Bugzilla46310
2022 BX2680 198? AC 916H
May 22, 2022
184
185
Demotte, IN
McCoulloch in Lowell Indiana might have the set of R14’s that came on my tractor. We ordered it with Turf and they swapped the tires with only about 20 hours on them. About 3 weeks ago.
WAS BANNED FOR NSFW PICS
5,152
He is from Upstate NY, so shipping them would be prohibitively expensive. He can buy new wheels and tires as a whole goods purchase from a local Kubota dealer than pay to have used tires and wheels shipped
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
868
canada
I am thinking R14's for my next tractor. I saw a set of R14 radials on a MX5400, they looked awesome.
xrocketengineer
Nov 14, 2020
800
722
Merritt Island, Florida
I got the 26X12.00-12 OTR 350 Mag as a larger wheel /tire upgrade for my BX1880 (with matching front size) to replace my R1's that had torn up my lawn. These are much better riding, better traction since I hardly use 4x4 now and the lawn is looking better.
