BX25D instrument panel and water damage
cbaracuta
Bx25d
Jun 10, 2020
Mo
I think it's time to bite the bullet and get a new dash panel.
http://www.colemanequip.com/parts/KubotaParts/K2771-62510/
So my gauges quit working but the lights still worked. I read everything online and thankfully found this page. I checked all the fuses and grounds and nothing. So I ordered the new panel as last ditch effort. Turns out all the comments on this page were spot on. Previous owner left tractor outside all the time which did cause water damage. Even though I kept it in a building for the last 6 months there was still a lot of water that poured out when I took it out. Most the internal pieces were brown and corroding. The new panel slipped right in and everything works. So if your a bx owner and it gets rained on, you will likely need to replace the panel at some point in the future. Thank you to all on this thread, It will probably help a lot folks like me.
cthomas
LX2610 HSDC
Jan 1, 2017
866
576
La Farge Wi
I had mine replaced under warranty twice. The Service Manager showed me the TSB(technical service bulletin) that was issued in late 2017. Supposedly Kubota fixed the issue from that point on. If it goes out again the Kubota area rep. might allow some money in goodwill.
Shadow Lee
BX25
Mar 5, 2021
Folsom, CA
Corrosion clobbered the instrument panel and mating connector beyond repair on my BX25. I ordered a new panel for $290 from Kubota and a new connector with 10 inches of leads (called a pigtail) from Findpigtails.com. Pigtail part number was F21B16 and it cost $80.
It took about two hours to splice in the new pigtail. I used two layers of heatshrink per connection.
Note that the connector terminals are referenced with numbers on the schematic but letters are used on the instrument panel.
I strongly suggest that you cut and splice one wire at a time as I had mediocre light so the colors below may be off!
I suggest that you cut off the four unused pigtail wires since they could be conneted to something in the panel.
Here's the wire colors and terminal (note that I had mediocre light):
Terminal
Position Color (yours may vary so again cut and splice one wire at a time!)
A -- empty (cut off pigtail wire)
B -- RED/GRN
C -- BRN/GRY
D -- BLU (connector locking tab at this location)
E -- GRN (connector locking tab at this location)
F -- empty (cut off pigtail wire)
G -- BLU/RED
H -- WHT/RED
J -- RED/YEL
K -- empty (cut off pigtail wire)
M -- RED/WHT
N -- WHT/BLU
P -- YEL/GRN
Q -- empty (cut off pigtail wire)
S -- BLK
4,289
Bought a 2013 bx2370 to replace my 2002 bx2200. 2370 tach and hour meter not working. Took instrument cluster apart and found corrosion on the tach drive. Bought and installed new cluster.
Now when the key is switched on, the tach does its exercise from zero to max and falls back to zero as the panel boots up (old one never moved). Crank it up and tach reads zero and hour meter stays on 0.0 hours.
Checked for corrosion at the 16 pins... none. Checked for corrosion at three pin connector on alternator and it had some. Treated with corrosion - x to no avail.
Q) I saw where pin 15 is 12v power? (Pin 1-8 on top row, left to right looking from front of tractor / rear of cluster?)
Q) What sends the signal to the tach?
Q) What sends the signal to the hour meter to start the clock?
Any help appreciated...very frustrated at the moment.
I’m not knowlegeable about this particular model (BX2013) but many machines have their tach and hour-meters powered by the alternator. (I have a JD4329 engine which has a troublesome alternator/regulator which will not produce current until RPM is raised above idle...then it will work at all RPMs once its been activated by the increase in RPM.... When that alternator comes on-line.... ONLY THEN will the tach, hour meter, ammeter, etc. provide indications.)
Wiz
12
Dover, NH
My new panel fro
Terminal
B -- RED/GRN
C -- BRN/GRY
G -- BLU/RED
H -- WHT/RED
J -- RED/YEL
M -- RED/WHT
N -- WHT/BLU
P -- YEL/GRN
S -- BLK
My new panel from Messicks came with the pigtail. I didn't use it because I would have had to find the other end down by the engine.
jbridgestx
Kubota BX25DLB
Jun 22, 2023
Keller Texas
Terminal
B -- RED/GRN
C -- BRN/GRY
G -- BLU/RED
H -- WHT/RED
J -- RED/YEL
M -- RED/WHT
N -- WHT/BLU
P -- YEL/GRN
S -- BLK
A huge, gigantic THANK YOU for turning me on to "Findpigtails.com".
Where they even verified your part number of F21B16, still costing $80 was the correct one.
After going through their chat & sending picture of mine.
While after cheapest shipping & tax, $86.59 is a lot to pay for female connector and 10 inch wires to splice in for repair.
My BX25DLB connector, has blank spaces for unused terminals.
With all 16 spaces, including the 12 used terminals & 4 empty ones.
Completely cemented into connector with a white epoxy.
With no way to get highly corroded blue, always battery hot terminal, out to clean.
Or simply replace that terminal.
Kubota now only offering a whole wiring harness as best solution,
for $611.49. yikes!
I’m already positive that I will use “Findpigtails.com" to buy other broken connectors, which is just part of fixing a great many things.
But now, thanks to you & your post, I now have a very useful source of new replacement connectors.
Thanks again!
