BX25 front snowblower
53woodsman
BX25
Nov 18, 2018
UTTERSON
I,ve got a chance to pick up a complete B2772 front mount snowblower for $1200 but wonder if I can adapt this blower and mounts to my BX25 for front mounting?
I can find no info on this blower.
I am good at fabrication and welding
Charlie5320
BX2670
Jan 8, 2018
114
9
Springfield, IL.
Google is your friend. I looked at one I found one google, from what it looks like it will mount up with the correct hitch for your tractor. What all comes with it? It may be a little too big for a BX25 but the front mount looks like it will go right on. I believe they were really made for a B series tractor. You say complete , does it include the hitch and drive line? If the hitch is for a B series it will be much too long for a BX, I just went through this with my tractor. A hitch and drive line kit will run you 14 or 15 hundred bucks, if you can't find used. Check tractor house and see if they have a used setup for your tractor.
BAP
Dec 31, 2012
3,088
1,226
Charlie is right. A snowblower model starting with B is for B series tractors. A BX series snowblower will fit BX and with the right hitch a B series tractor. If you put your location more than a town name, someone might point you in the direction of a used one for sale. A B2772 snowblower is a old version of the B2782B snowblower and is 63 inches wide. Too big for a BX25 tractor.
NoBiffBetter
193
Silver Creek, NY. USA
Call the dealer and ask they should be able to look it up and see what all is different.. you May just have to buy a different mount or build/modify a mount so that it will fit.
