BX23S Tires / Rims on a BX2200
Wolsfeld6
BX2200
Apr 27, 2023
Washington
Trying to determine if BX23S 18x8.5-10 and 26x12-12 rims / tire combo will fit onto a BX2200 without changing the rolling circumference and affecting the drivetrain in 4WD. I appreciate any input as I've searched forums with no definitive answer. The original turf tires on the BX2200 need replaced and I would like to go with an R4 or R14.
WAS BANNED FOR NSFW PICS
5,145
Buy them from the Kubota dealer whole goods with the new rims, and it is a straight-up bolt-on fit.
3,121
Probably. BUT my BX2200 front rims would not fit on my son in law's BX23S. Apparently, the tire size is the same, on OD, but the wheel diameter on the BX23S is larger. So the smaller wheels of the BX2200 would not fit.
My guess is the BX23S wheel would work on the BX2200 fine. But I don't know for sure...
My BX2200 rear tires fit fine on the BX23S
5,145
The BX23S uses a 10" rim on the front, and the 8" BX2200 rim isn't compatible with the BX23S, but the BX23S tires and rims are all compatible with a BX2200.
