Well, you certainly saved me some time. Thank you. I have the same symptom, only my left BH control is hard for moving the arm down (forward). Disconnected BH as you suggested, and FEL works fine. Service arrives Thursday. I'll post whatever issue they find. Brand new 2020 23S. Took delivery last Friday. Should I demand a new unit? 6 hour on this thing, 3 of them spent trying to figure out this issue.
[/QUOTE
Just realized I never updated the resolution.. the main control valve was leaking internally and needed to be replaced. When the fluid warmed up it leaked through and you could actually watch the backhoe levers start moving by themselves.. pretty wild. So, if you’re experiencing issues like mine then you should check the caps on the bottom end of the control valve below the backhoe. If they have fluid in them then it’s bad. You can disconnect the hydraulic lines from the backhoe and reconnect to return back to the tractor and continue to use the loader, etc just fine. Disappointed in the quality control at Kubota... 19 hours and issue after issue...
I hope this thread is still active enough to get some feedback. So, the bottom line is tha for the six weeks I have owned my new 23S, I've been able to use it to cut grass exactly twice.
The FEL loader issue described earlier resulted in the dealer collecting my machine on 5 June, and returning it Thursday 25 June. They said that they fixed / repaired the kickstand, replaced the water pump, (I was smelling coolant) and replaced the valve on the backhoe left stick, which controls down boom pressure, as that was jammed.
I removed the BH and FEL without incident, and cut grass for about three hours today. Although it is quite finicky regarding how precise one must be in positioning the tractor in relation to the BH, the Backhoe reattached without issues. The FEL was another matter.
I lined up and tried to connect the hydraulics via the quick connect manifold. No dice. After two more position adjustments, the quick connect still wouldn't properly engage or lock. It was stuck about halfway down. I inspected the upper part of the manifold and found a piece of plastic or nylon stuck in the valve opening. See pic.
A quick call to the dealership service folks, and they advised me to remove the object and try again. I did remove the object, but it shot out of the valve and into the landscape. Couldn't find it. This time the manifold engaged and locked and we thought we'd fixed the issue, until the right side arm wouldn't lock onto the frame. I tried a few more times and remembering my lesson learned from years ago on my BX2380, disconnected everything and walked away. Service will be back out sometime soon to pick it up a third time.
Aside the normal gripes about having no machine, and being unable to do the work I bought the machine to do, am I crazy to think I bought a defective unit? This unit now has 17 hours on it, and I found the initial FEL / BH issue at 3.5 hours. What does everyone suspect was the plastic piece in the picture? Valve seal? Piece of broken hydraulic pump? My hobby is using the machines to get work done, not becoming a service tech. Any thoughts? I'm beyond disappointed and frustrated at this point. Looks like no corn for me again this year.
