BX2380 Mid Mount Mower Problem
Evergreenhse
Kubota BX2380, front end loader, mid mount mower, Hansa C13 Chipper
Jan 15, 2021
New Zealand
Hi Good Folks,
I've just had a 60 inch mid mount mower installed under my BX2380. It worked great for about 10 minutes. It still cuts great, but the mower won't lift up or down anymore and I can't adjust the height adjustment twist knob as it's stuck.
Any ideas out there please?
Cheers,
Jake Barker (New Zealand)
2,914
Jake,
the height adjustment knob can be a real PITA - wrap that knob in a towel or something that will enlarge your grip and give it another try. But before you do that - take a piece of wood, brick or whatever you find and place under the deck and lift it up on all sides and see if that helps.
So when you pull the handle back the deck does NOT rise at all or move at all?
Could there be a linkage problem - something loose up under perhaps?
imnukensc
BX2380
Sep 10, 2015
763
716
Midlands of SC
Height adjustment knob doesn't work unless the deck is all the way up. If the 3 pt goes up and down and the deck doesn't, then there's a linkage problem somewhere with the deck.
Toyboy
BX2230D - RCK60-22BX - BX5450
May 18, 2010
682
1,031
Hayward Wi
You have two black knobs to deal with. The deck height on the left and the flow valve on the right. Make sure the flow valve is open to allow the deck and 3pt hitch to travel up & down.
As mentioned earlier, the deck has to be at TOP of travel to easily change position settings.
Orangeglow
2015 BX2370
Jun 19, 2014
371
188
Prescott, Ontario
Here,s what works for me. Set rpm to 2K. Raise mower until you hear the relief valve kick in.
Then turn height adjustment knob clockwise. Others have stated you can turn the knob in both directions, but for me, it only works while turning the knob clockwise.
