BX2380 Battery
Ketchken
9
Fulton, NY
Any idea what would drain my battery dead? Tractor is only one month old and key was all the way off. It sat for a couple of weeks without being used but snow is coming tomorrow. It took a charge but what would cause that?
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
Assuming the alternator is working, must be a bad battery or a short to ground somewhere. I would slap a meter on it while running to ensure the alternator is providing charging voltage, then with the tractor off test for a current drain.
Orangeglow
2015 BX2370
Jun 19, 2014
347
164
Prescott, Ontario
Any idea how long it sat at the dealers before you bought it, or if it was ever fully charged at any point ? Try charging it up to a full charge, and see how it behaves after that. Or you could remove it, and get it load tested after you fully charge it up, to see if it holds a charge.
