BX2370 PTO cover leaking fluid
Vince1230
Bx2370
May 13, 2022
127
49
Honey Grove,Pa
I found a leak coming from pto cover. It is keaking at the bottom where the seal or g asket material is. I was looking to repair. Anything is should be aware of when loosing the cover like parts coming out . What is recommend gastket material? Any reason for leak or why gasket failed? New to me machine.
Thanks in advance
4,074
Can you post a picture of the exact spot it’s leaking? Few spots it could leak back there….
Are you sure it’s that spot and not dripping down from further up?
Vince1230
Bx2370
May 13, 2022
127
49
Honey Grove,Pa
It is leaking at the bottom were this gasket is. I checked above and also back farther and it is coming right at the seam. I thought I saw a post to be careful taking off the cover but I could not find again.
