I'm a new used BX2370 owner. I did my first cut with it not long ago, set the height to 3. Later I was playing with the FEL a bit so I tried to put the mower at max height, but I found I could only get it up to a 4 setting on the mower height dial, it wouldn't turn to "top", and now it also doesn't want to turn either way and seems stuck on 4. I always raised the MMM up to max height before trying to change that dial. I can't easily look at the height adjustment dial mechanism without taking the mower off which I didn't want to do just yet. I also didn't want to force it too hard because I know it wasn't hard to turn previously, and I'm not sure if I'm going to break something down there.
Any suggestions, or tricks with getting that dial to work nicely? I know before I mowed the first time I played around with that dial a bit and it seemed like it was working; if I set it to 2 it would drop low and if I set it to 4 it would drop not so low, etc.
Thanks,
N
Thanks,
N
