i have a BX2350 with the well known cracked plastic fender issues. tractor is low time and otherwise in good shape. i have read that i can swap a metal BX2360 fender in place of the plastic trash that came on this tractor. i was wondering if someone could verify that a metal BX2360 fender would fit on my BX2350. thanks
The BX2350 is the same "Tin" work as the BX2360. The BX2350 parts are not worth buying or fixing.
Go find or purchase the Hood (Bonnet) from a BX2360,BX2370,BX2660, or BX2670 they will all fit. You must use the new mounting bracket that came with the newer hood. Head lights are the same. I had to grind a little on the BX2350's bracket that was on the tractor a bit.
Go find or purchase the Rear fender from a BX2360,BX2370,BX2660, or BX2670 they will all fit. The bolts in the handles may not come out easily. I finally put an impact on them to remove and "JB-welded" new inserts in the handle's holes.
Go find or purchase the Plateform under your feet from a BX2360 or BX2660 they will both fit. The Brake pedal is on the wrong side of the BX2370. Or cut a hole if you find a free or cheap one.
There are 2 little silver brackets that mount to the radiator that keep the metal hood from rubbing on the lower bonnet, I bought those as well.
My BX2350 has a BX2360 plateform, BX24D hood, BX2670 rear fender. Every 5 years the plastic gets brittle and falls off. I got the hood for free because it had a bullet hole in it.
