BX2230 miss
Toyboy
BX2230D - RCK60-22BX - BX5450
May 18, 2010
667
1,012
Hayward Wi
Hi guys, got a curious problem. When finishing cutting the grass there was a couple times the engine seemed to momentarily stopped and picked up again... like a second or two. This happened 2 maybe 3 times when I was finishing up.
Last fall I replaced all the fuel filters and oil & filter. I always use fuel additive and a little seafoam to catch any moisture that may have condensed since I also snow blow with it.
I thought maybe a safety switch, but I was on flat level ground. The only change was I filled it with fresh fuel before cutting, #2 off road.
Not sure where to start? Any ideas?
phildac
1984 B8200E, L260F
Jul 29, 2009
203
Wentzville, MO
Toyboy,
Not likely, but there might be some trash in the fuel tank that is covering the fuel pickup hole. Just a thought.
Big Kahuna
Kubota 2000 L3010 HST with Loader ,1992 B7100HST , 1979 B6100E & 2007 F2880
Dec 23, 2011
369
9
Homer City, Pa.
Fuel problem, just went thru this myself, put fresh diesel in and nothing but problems, fuel had water and crud in it, plugged my filter, tractor took 2 fillings before it ran right, sounded like a miss, probably plugged an injector, running okay now, off road #2 diesel, must not be selling as much?
Big Kahuna
Toyboy
May 18, 2010
667
1,012
Hayward Wi
Big Kahuna
I was suspicious of the fuel but the station I get mine from sells a lot and I've never had a problem in 5 years.. I gave it a heavy dose of seafoam this morning and used it a little without the miss........cross my fingers..... next time I'll get #1
