B Bill hack New member Equipment Bx2200 Aug 8, 2013 5 0 0 New Bloomfield, Missouri Aug 26, 2013 #1 I had to replace the hydraulic hoses on my BX2200D. I relaced the filter and cleaned the screen. Is there a protocol for filling with new oil? I ask because am fairly new to hydraulic repair. Do I just fill with proper amount and start tractor?
GWD Member Equipment M7040, L48 TLB, BX2200 Jan 8, 2010 792 17 18 Northern California Aug 26, 2013 #2 That should do it. Then cycle all of the equipment through their cycles...like 3PH up and down a few times. Cycle the FEL, turn the power steering post to post, use the forward and reverse function of the pedal.
I ipz2222 Active member Equipment L235, bx2670 May 30, 2009 1,927 33 38 chickamauga ga usa Aug 26, 2013 #3 And recheck fluid level after cycling everything.
B Bill hack New member Equipment Bx2200 Aug 8, 2013 5 0 0 New Bloomfield, Missouri Aug 26, 2013 #4 Thanks for the replies. Never hurts to ask questions.. As an aside working on compact tractor sure is hard on 70 year old knees and hips.
