BX2200 Transmission Strainer Location
Kubotamy
2004 BX2200, 60" Belly Mower, 50" Snow Blower, 42" Bush Hog
Aug 3, 2015
St Cloud MN
I looked in the workshop manual and searched a bunch online. Couldn’t find the location of the transmission strainer. I read that it’s 26mm and near the left tire.
Is it the bolt that looks like it goes through the vertical tube, just under the left rear axle? Is it the large bolt in my pic? Thanks.
ETA: The pic rendered sideways and needs to be turned clockwise.
3,248
Yes, you are correct. That is where the strainer is located. See attached fig item 030. There are two o-rings as well (one on each side of the tube).
Kubotamy
Aug 3, 2015
St Cloud MN
Is 26mm correct? Of course Fleet Farm only carries sockets up to 24mm and wrenches are either 24mm or 27mm.
3,248
not sure, but it doesn't matter. You can use a large crescent wrench if necessary, as they really aren't that tight...That's what the o-rings are for.
If you have SAE, try 1" or 1-1/16".
Kubotamy
Aug 3, 2015
St Cloud MN
Picked up a 26 mm socket at the auto parts store. Thanks.
4,068
When I got my Kubota, I ended up buying several individual sockets 26-30mm or 32..just in case. At $3-5 each, cheaper than buying a set.
If you have a mower deck, the deck bolts may be 30mm.
3,047
30mm = 1-3/16 IIRC
SidecarFlip
Banned
548
I try to refrain from using s 'West Virginia Socket Set' whenever possible they are real good at rounding off hex head bolts.
Harbor Freight has a complete Metric or SAE set for 20 bucks each in black oxide (impact) and they are indestructable. I know, I've tried.:)
