I am a new member. I purchased a used bx2200 about 6 weeks ago. I have been pleased with the tractor so far. My bx has a FEL and bellymower. I was using the belly mower for the second time. After an hour of mowing I turned the PTO off. Drove to the other side of the property to continue mowing and the PTO would not engage. The power steering works fine. The FEL works fine. The 3pt hitch and bellymower both lift up and down. The only issue is the PTO will not engage. I checked my fluid level. It is ok. I read a post from 2019 https://www.orangetractortalks.com/forums/threads/pto-not-engaging-in-any-position-bx2660.39135/ that perfectly describes my PTO issue and a possible solution. My question is whether my bx2200 has the same hydraulic components as the bx2660?Can I access the pressure relief valve and clutch spool valve on my tractor the way it is described in this previous post?
Thanks for any info
Thanks for any info
