BX2200 FEL
FREDGARVIN
KUBOTA BX25
Jan 14, 2014
Vermont, USA
I have a FEL question on a 2001 BX2200 with the LA211. All has worked great for years until recently the control is beginning to feel looser. Age and use I'm sure. This is all about bucket roll. Nothing has been changed, disconnected and so forth. You roll the bucket down and forward and let go of the control lever and the bucket sometimes not all, will roll itself back and up by itself. Thereby dumping the firewood you just brought in neatly. Is there a detent, or spring in or around the spool that wears out? No leaks of any kind unless internal. If you pay close attention you can easily control it, but sometimes when you back up or are looking elsewhere for a second it does it's thing and makes a mess. I'm sure someone has had this happen, thoughts would be great, thank you.
