Have a well-used BX2200 with electrical gremlins I can't figure out.
Several issues- the first is that the tractor won't shut off when the key is selected to "off". Previous owner rigged up a coat hanger on the fuel control to shut it off, which works but leads me to believe the tractor may have a lot more time on it than advertised, as the tractor runs fine with the key "off". The headlights have not worked in the time I've owned the tractor, and both have tested-good bulbs.
Second, and this one is a bit newer, all the lights on the dash and the rear running lights light up when the tractor is powered on. Position of the dash switches changes nothing. There are several "aftermarket" connectors under the seat that lead to nowhere, and there's a connector on top of the engine also connected to nothing.
I'm assuming I have a bad ground somewhere, or a short, but tracing out all the wires I can has revealed no faults so far. Any thoughts?
