bx22 power steering hoses
markwmer
kubota bx22
Oct 27, 2026
ga
what happens if i connect the power steering hoses in reverse? will it harm the tractor? i have lost track of which hose connects where under steering wheel
11,375
It might harm the steering controller if you put input to output.
The WSM will tell you which hose goes to which port.
View from sitting in the seat:
Supply will be lower right port
Return will be upper right port
Right side of the steering will be upper left
Left side of steering cylinder will be lower left
7,408
Which hoses?
If you reverse the cylinder hose it will steer in reverse
If you reverse the supply and return hoses it probably wont steer at all and the transmission may quit working.
Neither should damage anything. Its easy to determine which hose goes where
