BX1860 will not start
whitetiger
Nov 20, 2011
3,636
2,060
Kansas City, KS
This is the correct operation of my machine. There must be opposite set ups out there. Thank you.
There are actually three electrical shut-off setups that Kubota commonly used on these engines, the solenoid can be mounted above the pump, inserted into the rear of the pump, or inserted through the front cover into the pump. The latter is used primarily in industrial applications.
Some are spring-loaded to the RUN position and others to the OFF position.
