BX1500 Hydraulic Issues
Shadtree22
BX1500
Oct 22, 2020
South Carolina
I recently picked up a 2004 BX1500 for fairly cheap. Previous owner said the hydro filter blew off at the gasket and was no longer operable. (confirmed as filter was swollen and no seal was present).
I drained all the fluid, replaced the filter, cleaned the screen, added new UDT fluid, freed the F/R pedal, and now have F/R operational. Still some issues as after driving a while, the tractor will start jumping and then completely stop. Let it sit for a while and it starts moving again.
Another issue that's strange, is the 3PH is not working, checked the float knob, turns freely, removed top case and replaced lift piston seals and main hydro line, removed and cleaned/checked the hydraulic control, no stuck valves.
The steering also feels very weak and sluggish.
I've gone through about everything (checked main pump and it seems to be fully intact and no issues), without getting into the HST I'm completely at a loss as to what's going on.
Could anyone give some advice on what I need to check next?
8,531
Sounds like you have a pressure relief issue, or some other issue where fluid is not flowing freely through the system and is over pressuring and overheating.
Shadtree22
BX1500
Oct 22, 2020
South Carolina
I've been digging into forums and could the charge relief valve cause similar issues? Just got some more info from the previous owner and he said the hydro filter expanded and blew out the seal.
whitetiger
Nov 20, 2011
3,118
1,546
Kansas City, KS
Yes, the charge relief vale sticking would damage the filter. Remove the relief valve and see if the spool slides freely in and out of the bore.
The charge pressure relief valve is in between the P1 & P2 relief valves.
Shadtree22
BX1500
Oct 22, 2020
South Carolina
Awesome!
I will check it this weekend and update you on my findings. Thank you :)
I'd love to do it tonight but I've got a 2 year old and a 2.5 week old so my extracurriculars are limited. Lol
