bx transmission cooler
2,827
Well on the BX - you have the might well hidden expensive as hell cheap plastic fan that does all the work for you in the cooling department!
Before I would add a cooler - I would check under the belly of the BX and make sure of two things - fan blades are still intact and the case is clean and air can flow over the fins.
