BX tractor , front weights and grill guard
Kurtee
BX2660, BX2680 cab, JD 2032R, Honda 5518, JD X590, JD X739
Oct 3, 2013
319
107
Nicollet, mn
I had a plate bent to hold 2 100 pound suitcase weights that hooked on the grill guard of my BX2660. Works well, just had 2 3/8 bolts tapped into the guard to hold it and used a ratchet strap to keep the weights in place. I no longer use it as I bought a bigger tractor to do what I was doing with the BX. You should be able to do something similar to hold whatever weights you are using.
OrangeKrush
Nov 15, 2020
1,044
514
Indy
Have a BX2350 need to put weights on the front end , I also have a grill guard. Do I need to remove the grill guard to put the weight bracket on or is there a work around ?
Photos or more info would be more helpful!
Mrlunchbox
2023 BX2380 loader/mower. Land Pride snow pusher, Kapteyn pallet forks
Nov 21, 2020
359
155
Southern Worcester County, MA
OrangeKrush
Nov 15, 2020
1,044
514
Indy
OrangeKrush
Nov 15, 2020
1,044
514
Indy
I really like that set up.. looks like a really well thought out design.
After a second look is that a package deal or are they separate manufacturer's?
B737
LX3310
Jun 9, 2019
2,022
2,203
the brush guard is from "Earth & Turf" in New Holland PA, and the little bracket I just made from a steel scraps, its just a box that gives the 40lb weights something to grab onto. It was compact and worked well
OrangeKrush
Nov 15, 2020
1,044
514
Indy
Nice work!
Dieseldonato
Mar 15, 2022
728
439
Pa
Where did you get the weights? They are a lot nicer the front kubota weight I have, and look like they are shorter then the suitcase weights I currently have.
B737
LX3310
Jun 9, 2019
2,022
2,203
they are the standard 42 pound weights from deere, they keep them in stock, so you dont have to pay for shipping.
savoy9020
G1800, L2501 (2016) 5ft LP box 2004 F250 6.0 Lariat Supercrew 2017 1140D RTV, 2
May 25, 2016
50
Savoy, Texas
I'm getting a BX next week and would love setup these. weights. They are very plentius on E-bay as well.
do you have the dimensions of the box you made?
