I was looking for an easier way to apply weed and feed over three acres when I found a 40 gallon 3 point sprayer with wand on sale. Also picked up a 2.5 gl jug of liquid weed and feed, 15-0-0. The broadleaf chemical in it is 2-4d.
Having never sprayed with type of equipment, I had to figure out how to get the recommended application rate applied. It was clear tractor speed is an important variable. Without a speedometer on the BX2370, I used a handheld GPS to determine speed based on lo/hi range and rpm. With the HST pedal fully depressed, the results were:
rpm / lo range mph / hi range mph
1.5K / 1.7 / 3.5
2K / 2.3 / 4.8
2.5K / 3 / 6.6
3K / 3.6 / 7.8
I haven't sprayed anything yet, still learning and converting. Sure would be nice if the sprayer makers and chemical makers used the same measurements!
1.5K / 1.7 / 3.5
2K / 2.3 / 4.8
2.5K / 3 / 6.6
3K / 3.6 / 7.8
