BX series
man00
197
12
okla
I was wondering about the BX line with backhoe other than digging a ditch what use are those backhoes? I seen guy trying to dig up a stump (pretty big one) for like one full day and didn't get much done. I thought he was going to destroy the tractor. Then next another guy came with a mid size excavator within 30 minutes the stump was gone. Maybe he was just asking too much on that job for the BX to handle.
edritchey
Ferris IS800Z - New Holland WM75 - John Deere X500
Jul 19, 2014
1,117
819
Wellsville, PA
Stumps can be tough on any machine I dug out stumps with my John Deere 510 that it couldn't lift out of the hole and I ended up digging a bigger hole next to it and rolling the stump into the big hole and just covering everything up.
BX tractors only have a few hundred pound lift capacity they are tough little buggers but you still have to use some common sense.
5,671
Well in the year I've had my BX23S I've
dug a 300' French drain system
dug 2 6' deep catch basins
dug up 10-12 nasty tree stumps
'relocated' thorny bushes way back into the pty line
lifted 3-4 car engines and trannies into pickups and trailers
'adjusted' several 24x30 and 30-48 patio stones
carved side of hill to install 14 step steel staircase
carved more to add 6" drainage tile
moved and 'fluffed up' over 100 cu yds of compost
same with 50-60 yards of wood chips
created some 200-300' long shallow swales
created a new firepit
that's what I can remember......
Jay
jmf78
BX23S W/ Factory Deluxe Cab, 60" MMM, 60" BX-2612 Snow Blade & BX-2816 Blower
Nov 5, 2015
437
Edinboro, PA, USA
I had 3 40-50 foot tall willows fall. Cleared the roots with my BX. Pulled the stumps out with my Tacoma. It took time but got the job done.
Fixed a couple of drainage issues. First was 250' long. Second was 100' long.
Helped a friend with a drainage issue at his cottage. See picture below.
Cleared out some tough rooted grasses for my mother in law
Unloaded a 500 lb. Plus log splitter from a delivery truck and moved it to my garage with clamped pallet forks.
Spread mulch.
Move dirt, gravel, etc... easily.
Mow my 3.5 acres easily.
Plow 600' + of snow in northwestern PA (snow belt off of lake erie)
Is it the best tool? For everything? Not necessarily. Gets the job done for me.
Sent from my SM-N960U using Tapatalk
MadMax31
BX23S, 60" MMM
Nov 5, 2014
763
New York
She has her limitations sure,
But Ive planted 62 trees on my land, installed 2 retaining walls, 2 drains for gutters and my above ground pool.
For the price, why not?
shiraz627
BX23S Piranha toothbar, Underarmor, PFL1242 pallet forks, BXpanded thumb, ripper
Aug 1, 2018
206
Kingsland. GA
You need the right tool for the job! I have Southern Yellow Pine where I live and those stumps have deep tap roots. I typically just have them ground although I did try burning one.
