BX RUNNING HOT...Or Not?
6,873
Comes up often, and often they can run hot. Usually gummed up radiator.
Started mowing other night and within ten minutes I see this:
Holy smokes!! (Not what I really thought)!!
But wait a minute...haven’t run long....
Shut her down. Get laser thermometer. Top radiator hose is 135F, bottom hose is 95, and the valve cover is 127......not even to operating temperature yet.......hmmmm....
Radiator full to top, and cleaned out last week. Reservoir is good. No bubbles in radiator when running (indicator of probable head/head gasket damage).
Pulled wire off sending unit:
A little brush-brush and wiggle-wiggle. I got this on re-start and it never moved while mowing. It was about 80F:
I’ll put some dielectric grease on that connection because it’s gotten me before.
For you new guys, ALWAYS heed what the gauge says.
Don’t assume the gauge is wrong. You could end up overheating your tractor causing thousands of dollars in damage.
A $10 or 20 laser thermometer is worth it’s weight in Gold!!
thepumpguysc
267
Sunny South Carolina
REAL GOOD info there, RCW..
I'm surprised the engine didn't shut down..?? I guess it doesn't have a temp safety switch??
I've been read a few of your answers to posts.. sounds like you've got a REAL GOOD handle on the operation of these things.. Thanks for posting..
Vacula
BX1500, LA181, 54" MMM, JohnnyPlow Sr, Heavy Hitch, Box Scraper
May 10, 2017
76
Clinton County, PA
I would be shocked if my BX or my employer's RTV gauge moves that far! Both run cold to hot using the lower 10% of the gauge! :)
Thanks for the post. Sooner or later it will happen and if it does, I would rather it be a loose connection!
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
337
100
Ottawa, ontario
There never was an overheating issue as it was the gauge giving a false reading. That's what the post was about.
6,873
The other point is If you see a gauge like that, treat it as if it’s a problem until you prove it’s not.
That’s where those laser thermometers are handy in the case of a possible overheat.
6,873
I would be shocked if my BX or my employer's RTV gauge moves that far! Both run cold to hot using the lower 10% of the gauge! [emoji4]
I’d be apt to check them with a thermometer also.
While HOT isn’t good, hot is. Running them cool isn’t good either.
It would just help you know they’re getting to proper operating temperature.
whitetiger
Nov 20, 2011
3,185
1,604
Kansas City, KS
This model does not have a high engine temperature shut down.
Trail
BX2360, FEL, 60" Deck, Rear Blade
Dec 11, 2016
69
Wisconsin
Good info and I just started a Thread regarding this issue. Mine goes to red when its not hot. I may be trying some of these things out.
