BX mowing in high or low.
Smoke244
BX2200 with cab and snowblower
Aug 15, 2020
9
Roscommon Michigan
Mowing 5 acres with a BX2200, belly mower. Very few turns or timing, any issues mow
Ing in high range?
7,349
I do most of my mowing in high range.
imnukensc
BX2380
Sep 10, 2015
797
768
Midlands of SC
I do all of my mowing in high range, but I have no hills and the grass is centipede and never over 4" high.
Mlarv
BX23S
Jan 19, 2020
227
179
Crossville TN
I have a BX2380 with MMM. I mow on high for the most part. If the grass is high or I hear the mower bogging down I slow down and let it cut. Part of the field is wet most of the year so 4WD and low to cut it. I guess go by the sound.
3,400
Ing in high range?
I'm not sure the range selector is as important a consideration as is ground speed.
I do have hills and I run the engine WOT (wide open throttle) in low ramge when cutting grass. Also mostly have the directional pedal fully down for maximum speed, again in low range.
For me, high range with a little directional pedal to attain the same speed would not work well, due to up grades.
Never felt the need for more speed than full pedal in low range gives me, as my property is kind of bumpy. Bounce around pretty good as is.
I would guess the quality of cut suffers as speed increases. Other than that, if I were you, I would run as fast as I liked in high range at WOT and see if I was satisfied with the results. If not satisfied, I would slow down a bit and find what speed gave me the results I liked.
5,679
Well you flat landers :) up there in Mi High range is no problem. Hell Im in the coal country and I run in high all the time,,unless the grass is realllly high. No problems up or down hill with the old BX,,, Just remember to keep the RPM's up dont lug the little beasty down when you are mowing
3,400
How about ground speed? Do you run less than full pedal when in high range? Do you end up running faster than you could with the pedal fully depressed in low range?
I would think the advantage of running in high range would be getting higher ground speed than can be attained in low range.
I actually wonder if there is an advantage of running in high range over low range if the same ground speed is used.
Anybody know? I sure don't. But I feel like it would be preferable to use the lower range if there is overlap between the ranges.
But I ABSOLUTELY do not know. Thus the question...
OrangeKrush
Nov 15, 2020
1,044
517
Indy
I don't have a mower on mine but I understand where he's coming from with that question. There are times you just want to make up ground without having to stop and put it in high gear, doesn't mean you need to keep the pedal to the metal continuously. I think about this when plowing snow sometimes but mainly keep it in low even though it pushes and pulls it well. Like said.. listen to the tractor for the most part and use common sense.
3,400
Myself, I am not sure I understand where the OP is coming from with his question.
Three choices:
Run low range: Get a maximum speed which is lower than high range
Run high range: Get a maximum speed that is higher than low range
Run either range: Get either a speed that is greater or less than either range can duplicate, with some overlap. Depending on relative position of the directional pedal.
OrangeKrush
Nov 15, 2020
1,044
517
Indy
Three choices:
If I had it in low and that's all the speed I needed.. wide open.. then yeah low range is where it would stay. There are times when you hit those thinner spots of grass or maybe just turning around where you might want to gain some speed to save some time. 5 acres is quite a bit on a BX in low gear full time.
3,400
I cut five acre regularly and do not find using low range all the time to be an issue. Perhaps I just got more patient as I aged? LOL
edit: That is WOT and full speed, of course... :)
armylifer
Mar 26, 2013
2,331
1,086
Thurston County, WA
I run slow in high range because I have arthritis in my ankle and pressing the pedal harder in low range is more difficult than pressing lighter in high range, for me. If arthritis were not a factor I would use low range and more pedal.
SRRGC1
BX1870-1, BX23S TLB, RTV XG850, MX5100DT
Jan 6, 2021
223
77
Bloomsburg
If you really enjoy cutting grass AND have alot of time on your hands, use low range.
