BX Hazard Lights
billwisdom
BX2230, LA211, Box Blade
Jul 6, 2015
29
Robertsville, MO
For what it's worth, I noticed on some of the other forums people indicating they had issues with the hazard lights on their BX not working. My hazard lights were not working as well. The fuse was not blown, and there was proper grounding. I pushed the switch out from the under side of the dash panel, pulled the switch apart and cleaned the contacts with electrical cleaner, applied a little electrical grease and put it back together. Less than 10 minutes and now they work fine.
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
17
Northern California
Yeah, but I'll bet they got wet in the past.
The switches are definitely not waterproof. Some guys have unique solutions, but I'm waiting for a direct replacement that is waterproof. Doesn't have to be Kutbota but needs to work flawlessly and just pop in without a bunch of cutting or fitting.
ThisIsNotaStep
2005 bx23 tlb
Nov 26, 2010
133
Ontario, Canada
Better recheck that switch, if not re-assembled correctly they'll blink on when the should be off and off when they should be on ...
5,320
Sounds like somebody has had some first hand experience with that,,,lol
