BX gauge cluster removal ???
Yoder409
BX1850, B2630, L2350, MX5000, M6800
Jun 9, 2019
19
Swellview
Trying to replace the gauge cluster unit in my BX1850. The replacement cluster LOOKS like it should just pop in/pop out of the dash. But the old one does NOT just pop out. The whole top edge starts out...…….like it's gonna come right out. But it doesn't.
Can't find a thing on YouTube about it. Anyone know the secret to getting the old one out ??
3,248
looks like it's just held in with tabs...
see below from kubota books...
whitetiger
Nov 20, 2011
2,604
1,116
Kansas City, KS
It pops out, not real easily. I use a small screwdriver between the panel and dash to help it out.
Yoder409
Jun 9, 2019
19
Swellview
That's what I was doing, too. But the panel coming out wanted to break and/or pull apart at the seam.
I guess...…………..if I'm taking it out because it doesn't work and I'm replacing it...…...what does it matter if it's gooned up when it's finally out ?? :rolleyes::D
4,090
If you can GENTLY compress a tab with screwdriver, slide in a piece of 'shim stock', remove screwdriver and repeat for every tab, it should come out OK.
Best if done in a WARM room of course and PATIENCE is the key !!!
While i haven't done mine, I've replaed a LOT of 'computer screens' and such this way...
Yoder409
Jun 9, 2019
19
Swellview
Thanks for the shim stock tip.
Biggest thing might be that I'm doing it outside...……….30-ish degrees. I think I may hold off on this til things warm up and soften up a bit.
