Three years ownership of by BX1870 and I just had my first breakdown. I was mowing and looked down to see 0 on my tach, and the digital dash dead as well. Didn't notice any other symptoms, so I finished the 5 mins of mowing I had left. Then when heading up the hill back to the garage, the power dropped significantly to the point where it almost stalled. That got me concerned.
My first check was the fuses, and sure enough one 15A was blown. Upon replacing it the dash came back to life, so I started it up again, and the dash died immediately. Was still running fine, but now that my hearing protection was off, I noticed a very slight flapping sound that I couldn't detect before.
In crawling underneath I found what you see in the attached image. The rubber boot on the engine side of the driveshaft somehow shredded, and as it was flapping around it severed the wires leading to the lift pump, leading to short and the blown fuse. The good news is that the power loss was almost certainly caused by the pump being out of commission.
The bad news is that the pump wiring appears to be part of the main wiring harness, which if I've looked it up correctly, Messick's charges $462.42 for. But I can splice in wire to do an effective repair, so I'll take that route.
The other bad news is that to get a replacement boot on, I've got to remove the driveshaft. I've read about doing that on the propeller/hst end. Is it any easier on the end I'm dealing with, given that I only need to create a small gap? I haven't studied the components yet, but if get it unbolted, is there any play such that I can slide a new boot over the end?
If it's not that simple, I might want to take it to the dealer. But this time of year I'm afraid it may take them a while, and the cost estimates I've heard for dealer fan replacement were significant.
Any help will be greatly appreciated.
