BX Brake, Forward, Reverse Rubber Pads
bluedunn
BX1860, FEL, MMM, Heavy Hitch Back Plow Blade
Aug 29, 2019
304
40
Thetford, VT
Hi-
Anyone know if the rubber brake, forward, and reverse pads are easily removed on the BX? Are they glued on or just friction fit over something?
Thanks!
dlsmith
BX2230, LA211
Nov 15, 2018
1,360
1,061
Goshen, IN
Which BX model are you referring to?
I believe newer models are different from older models.
SidecarFlip
Banned
563
Were glued on, on both my M9's. Replaced them, cleaned to glue off with mineral spirits. New ones slipped over the pedals so no glue needed.
dlsmith
BX2230, LA211
Nov 15, 2018
1,360
1,061
Goshen, IN
Oh, sorry, didn't realize - I'm referring to a BX1860 from 2012.
My fault, you have that right on the left side of your post.
I typed before I read it.
Should be easy to tell how they are attached, just peel one back to see.
FYI, brake pedal cover is K2581-43190.
Forward pedal cover is K2581-42310
Reverse pedal cover is K2581-42320
bluedunn
Aug 29, 2019
304
40
Thetford, VT
I’ll take a look this evening. I’m hoping for just friction...but as I’ve come to learn, hope alone is never a great strategy.
Thanks!
E10
NY
If my newer bx80 is any indication they are attached with grease and/or a heavy spring that pops them off!
