BX 3-Point Hitch Alternatives
Steveorange
BX2200
Jun 4, 2026
Ontario
I recently bought a BX2200 with most of its three-point hitch parts missing. The dealer wants $720 and Amazon wants $400+. I think this is too much! I have a heavy duty turnbuckle that seems to be the right size for the top link (13” closed, 18” fully open). I have another turnbuckle that fits on the lower link and I can get another at the hardware store. I can weld up some lifting rods. Is there any reason to not use these parts? The attachments I want to use on the 3-point hitch are: snow blower, box blade and ballast box. Thanks for the advice. IMG_1603.jpeg IMG_1604.jpeg
snoeproe
BX23s
Feb 19, 2026
10
My dealer quoted me $500 for a complete 3pt kit this spring for my bx23. kubota brand. You will be happier with the kubota kit.
Blue2Orange
BX2380 with LA344S & QH05. SB1051. SG0554. BB1248. RB0560, Vassar dirt bucket
Apr 3, 2025
411
289
Bayview Township
Pick up a pair of these instead of the turnbuckles, you won't regret it.
+1. The only negative on the BX2380 has been the 3pt mounted snowblower. The plastic safety bell shaped shield clearance with the 3pt bottom hinge, spacer plate needed to be flipped bottom side up. The plate on the OP's bottom photo where the turnbuckles attach to.
I have couple implements that are not QH compatible. Need to adjust the various width needed at the pins. Sliding stabilizer bars make life easy. Plus the stock turnbuckle units look to be less robust.
