While mowing my BX 2670 started losing pto power. Checked hydraulic fluid dip stick and fluid was all frothy. Let it sit a while ran fine. Started again and got frothy and losing power. Anyone else run into this. Ideas? Thanks
it sounds like it is sucking air. any signs of loose connections (wet fittings)?
Also, maybe it's overheating. Is the hyd cooling fan under the tractor still in one piece (all fan blades accounted for)?
