BX 24 BX25 BX2660 Control valve
Wawajake
BX 2660
Apr 20, 2011
I own a BX2660 subcompact tractor with FEL (bought in 2008) I have had to have a few repairs made to my hydraulic control valve due to the o rings blowing out ( the FEL bucket boom valve located under the battery box)
Now on other tractor websites a few folks have found that Kubota recognizes there is a problem with the flare design on the alum pipes that exit the control valve , these flares might be to rough on the orings. I am told replacement alum pipes are slighlty different flares and it solves the problem. But only by really pressing their dealers did they get these repairs. Now I don't care how much it will cost me (warranty is expired ) so I understand that, but can anyone tell me if a TSB (technical service bulliten) listing can be found . I know some car manufacturers have websites where TSB's can be found. But does Kubota? or does anyone here know of this TSB ? As it is ,the orings seem to last 50 to 80 hours then blow out and you lose all use of tractor very quickly, then they change the o rings and you hold your breath for another 50 hours . Any thoughts ??
NoName223
BX24 Loader& Backhoe
Oct 15, 2011
Snoqualmie Wa. USA
I have a 2008 BX 24 and have had the same problem, this is the third time in the 80 hours of run time ive used my tractor, the dealer fixed the it the first two times now they want to charge me. the problem has been the same each time the o-ring on the loader controller is blown out... a new ring cost $2.25 and $100.00 for labor and $100.00 them to come pick it up....I am going to try it myself... its reallly tight working space anybody have any tips on approaching this... at this point i am going to try ans disconect the line at the bucket quick connect fitting and fish the new o-ring down the metal tubing all the way to the loader controller and slide it over the port and into place.
Kubota_Man
BX24, Rear blade, Front blade, Snowblower, 54" MMM, Box scraper, Landscape rake
Dec 25, 2010
953
Kellogg, Idaho
I had the same issues with my BX24. I had it in 4 times for repairs during the warranty period. On the 4th time the service manager said that they were going to replace all 4 tubes as per the Technical Service Bulliten all under warranty ( lucky me :D ). Now I have blown 2 o-rings after the replacement tubs. You can change the o-rings yourself. Take apart the plastic housing that surounds the loader valve. Then the fun part start the tractor to identify the one that is blown move your loader joystick in all directions with your RPMs slighty above idle while looking for the leak. Then Loosen the tubes at the quick conects and then with a large (I can't remember the size) long wrench lossen the tube at the loader valve. this will be a time consuming part as you will only be able to make short strokes and have to turn over the wrench most every time. After you got it disconected fish out the bad o-ring. Then put everything back together up to the point of the plastic housing. Verify you have everything sealed back up by starting the treator and move the loader joystick agan. Depending on the amount of fluid you have all over use 1-2 cans of break cleaner to clean all of the oil off your loader valve. Install the plactic housing and cowling and go have more fun :D
As always I'm not an expert but this has worked for me :)
