Hopefully this is a simple newbie operator error issue, but I'm stumped and not too proud to ask before I break something!
Operating my post hole digger off the rear PTO, manual says to put MMM in "TOP" setting to lock it from dropping while using the PHD. Check, did that. MMM stayed up while punching holes.
Now back to attempting to mow. Cutting Height adjustment will not budge. Drop speed control knob to the right is in either mid or fast drop (open) position. Before using the PHD the MMM cutting height control was pretty stiff but did work.
Mower manual is little help, just says turn to select desired height. BX23S, 54" standard MMM, Land Pride PD-10 PHD if it matters.
Thanks in advance for the secret.
