BX 1880 - Do I need a 3rd Function Kit For a Grapple?
BX1880Dude
2022 BX 1880
Sep 19, 2022
Dayton, OH
I dare not enter the "grapple" thread chaos, I simply would like to know what Grapple for the BX 1880 and do I need a 3rd function kit?
(Conversely I don't need opinions on the size and work and scope, I would just like to know what grapple if any will work and do I need a 3rd function kit or not to utilize it, I have the SSQA)
xrocketengineer
Nov 14, 2020
914
879
Merritt Island, Florida
Yes, you need a third function kit. There are two options that I know off, a real third function or a diverter valve that switches one of the joystick function for the grapple while pressing a button. The diverter system might be cheaper and easier to install.
I have the Land pride third function kit and the SGC0548 48 in. grapple (pin on and no longer available) that I bought with the tractor. The SGC0554 is the SSQA equivalent in 54 inches. There are brochures and manuals in the link below for the installation and operation of 3rd function kit and grapple.
notforhire
Kubota L47
Dec 5, 2019
148
69
Meadows of Dan VA.
If you have rear remote hydraulic connections you can run the grapple off of those. You will need to run hydraulic lines from the grapple piston back to the remotes.
Other than that method you will need a 3'rd function.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,447
1,743
Kalamazoo, MI
Get a Brush Crusher grapple from Good Works Tractors....no third function or diverter valve needed.
7,320
Depends on your definition of a third function kit. You need a way to ooerate the cylinders on the grapple. Electric operated control valve is the "standard" definition. A cheap manual valve or diverter for the loader valve will also work.
